kamomeno68 Posted June 8, 2020 Posted June 8, 2020 Is there an output data file parameter that shows the inverter DC input voltage? I see there is UArray for the DC output voltage of the array, but I'm interested specifically in the input voltage at the inverter.
Lazare Fesnien Posted February 11, 2022 Posted February 11, 2022 Hi, If you have not defined DC ohmic loss (Detailed losses tab) then DC output array = DC input VoltageIf you have defined a DC side wiring loss in this case the loss will be taken into account.We have not yet defined a viewable variable but it can be an improvement
