sanoj_j Posted June 1, 2020 Posted June 1, 2020 Hi,I am using PVsyst 6.86.When i use the self consumption option (no storage defined)Produced Energy is not equal to E_Solar+E_Grid. Should they not be the same?The difference is significant:Produced Energy (in PVsyst report) = 3201 MWHrE_Solar = 2366.6 MWHrE_Grid = 817.44 MWHrE_Solar + E_GRid = 3184.04MWHrPls clarify the same as this is leading to too many confusions.
Shashwat Posted June 17, 2020 Posted June 17, 2020 It could be a rounding error. Change the settings to kWHr and then produce the CSV file. With the file, you can cross-compare.You can refer to the online manual:https://www.pvsyst.com/help/
