lorran.leite Posted January 30, 2020 Posted January 30, 2020 Hello all, Im new on PVsyst, and i try improve my skills here learn from youtube videos and pratice on PVsyst.I have one project with 6 diferent orientation, but i want share inverter with diferent orientation (use 2 MPPT from inverter), its possible?I create sub-groups, when i simulate the result is use much more inverter (16 x 25KWP inverter) rather tham 9 (my calcs) My plant have +- 300KWpSub_group 1 with 308 panels +- 92.4 KwpSub_group 2 with 172 panels +- 51.6 KwpSub_group 3 with 264 panels +- 79.2 kwpSub_group 4 with 241 panels +- 72.3 kwpSub_group 5 with 119 panels +-35.7 kwpSub_group 6 with 72 panels +- 21.6 KwpWe want use 300w axitec poli panels and 25KW tripower SMA inverterWe need 9 inverter for this production, but if i simulate on PVsyst, i must use 16some one with whatsapp or facebook to help me please?thank you very much
dtarin Posted February 7, 2020 Posted February 7, 2020 (edited) Use MPPT share. When you select MPPT share, it will go by the number of MPPT inputs, not inverters, so total you will have 18 (for each inverter). Edited February 22, 2021 by dtarin
Muzammal567 Posted May 23, 2021 Posted May 23, 2021 Hello all, Im new on PVsyst, and i try improve my skills here learn from youtube videos and pratice on PVsyst.I have one project with 6 diferent orientation, but i want share inverter with diferent orientation (use 2 MPPT from inverter), its possible?I create sub-groups, when i simulate the result is use much more inverter (16 x 25KWP inverter) rather tham 9 (my calcs) My plant have +- 300KWpSub_group 1 with 308 panels +- 92.4 KwpSub_group 2 with 172 panels +- 51.6 KwpSub_group 3 with 264 panels +- 79.2 kwpSub_group 4 with 241 panels +- 72.3 kwpSub_group 5 with 119 panels +-35.7 kwpSub_group 6 with 72 panels +- 21.6 KwpWe want use 300w axitec poli panels and 25KW tripower SMA inverterWe need 9 inverter for this production, but if i simulate on PVsyst, i must use 16some one with whatsapp or facebook to help me please?thank you very much. Thanks for sharing this it's helpful.
wajoro4666 Posted August 4, 2023 Posted August 4, 2023 Wow, this post is really helpful! PVSYST can be quite tricky when it comes to using multiple orientations! but your tips and insights make it so much easier to navigate. Thanks for sharing your expertise and making solar energy planning more accessible to everyone. Keep up the fantastic work! ?? #PVSYST #SolarEnergy #RenewableEnergy
