Dear all,
let me wish you all the best for this new year!
Can you please tell me if the ground data imported through CSV file is considered when computing the shading?
Regards
Christophe Vernay
It can be considered a shading object if you check the box in the objects properties "enable object to cast shadow" or something similar. Then it will be considered solid object. If you use it, without this check, it will still change the module placement and as such, their shading, POA, etc.
