Krzysztof Posted December 19, 2019 Posted December 19, 2019 Hi,I can't import meto data from PVGIS because when I try, a following error occurs: "The columns for the dates are not defined or not sufficient".It doesn't matter which database or which site I choose. Curiously, I have recently imported the PVGIS data and no problem occurred. However, then I used an older PVsyst version (I think 6.80) than now (6.85).I also imported the data directly from the PVGIS website but when I tried to use them, the error occured again.Could you tell me what the error source can be?Thanks in advance!
Angelov Posted March 9, 2020 Posted March 9, 2020 Hi,I can't import meto data from PVGIS because when I try, a following error occurs: "The columns for the dates are not defined or not sufficient".It doesn't matter which database or which site I choose. Curiously, I have recently imported the PVGIS data and no problem occurred. However, then I used an older PVsyst version (I think 6.80) than now (6.85).I also imported the data directly from the PVGIS website but when I tried to use them, the error occured again.Could you tell me what the error source can be?Thanks in advance! I have the same problem!PVsyst team, please clarify what we have to do to fix it!Thanks!
anastasisp Posted May 4, 2020 Posted May 4, 2020 Since i face the same issue, i have sent an email to PVsyst. They informed me that there is an issue with PVGIS API servers, that is why we cannot import the weather data.
André Mermoud Posted May 24, 2020 Posted May 24, 2020 The problem with the PVGIS API change has been solved in the latest version 6.87.This version is available for any user who has upgrade rights up to December 17th, 2019.
