joubert Posted October 1, 2019 Posted October 1, 2019 HiIs it possible to get a single hourly output file for multiple (25) years by:using the same meteo data for each yearusing a specified degradation percentage in the aging setting under detailed lossesspecifying a grid limitation that is applicable every yearThank you
André Mermoud Posted October 9, 2019 Posted October 9, 2019 You can define different conditions from simulation to simulation using the Batch mode. Each simulation may produce an Hourly CSV file. But these resulting hourly CSV files will be independent. If you want to gather them in one only file you have to do that manually.
mohaned Posted February 15, 2024 Posted February 15, 2024 I am running ageing simulation, i need to produce hourly files, for a few of the simulation years, but they are not produced. is that possible? i ticked the generate report and output file tabs, and i get a pdf report, but no hourly file.
Agnes Bridel Posted February 15, 2024 Posted February 15, 2024 The hourly output file generation is available if this option is activated in the original simulation. This can be done through “Advanced simulation > Output file”. When this option is activated, you can run the multi-year simulation again in aging tool and the output files will be in the “UserHourly” folder of your workspace.
hdseo Posted October 5, 2024 Posted October 5, 2024 I did it also several times, but the output files are not generated. In the output file setting, the setting is complete with E_Grid, Glob_Inc and PR. I ticked the generate report, the generate variant, and the generate output file all. Finally, the reports generated and the variants generated, but, the output files not generated in the userhourly folder. Without the aging tool, in the normal situation, the output files are generated well in the userhourly folder, but, in the aging tool, the output files are not generated. Could you check any errors? or more specific guides?
hdseo Posted October 7, 2024 Posted October 7, 2024 It has been cleared. I have not chosen "File Name" but chosen "No Output" in the Output File Box. After changed to "File Name" from "No Output", the output files are generated in the userhourly folder.
