pedro Posted September 25, 2019 Posted September 25, 2019 Hello,When I try to open any project (that was working before) the program shows the following message:https://i.imgur.com/1YJ71rU.pnghttps://i.imgur.com/D6Pdj9I.pngIt says there is a problem with the file and it is already been used by another program.If I skip this problem and continue, I can`t even find any PV modules and inverters that should be the PVsyst default files (as shown in the image):https://i.imgur.com/I1EKF7F.pngI have reinstalled PVsyst several times using different folders with different workspaces and nothing solved this problem.Cleared the registryTested on annother machine..I think it's a compatibility problem with the Windows version.Does it have any solution?
André Mermoud Posted October 9, 2019 Posted October 9, 2019 This is really strange as this file should not be located here, in any way... I don't know how this could arise.Please delete the PVsyst.INI file, this should solve the problem.
