kjs55 Posted August 21, 2019 Posted August 21, 2019 V6.83: Many modules in the PVsyst PAN File Database have the wrong Pnom (leftmost column), e.g., for module type "TSM-295DD05A.08(II)" with file name "Trina TSM_295DD05A08_II.PAN", the Pnom listed is "255 Wp 26V" instead of "295..."
Lazare Fesnien Posted February 9, 2022 Posted February 9, 2022 Hi,This is not an "error". it is the manufacturer who has inserted these components into the database under this name. If you check Impp x Vmpp = Pnom, this corresponds to the Pnom defined in the file. File names are different for each manufacturer
