How to take into account of MV and HV losses on different sections
Hi everybody,
I have to to run a simulation of a grid connected pv plant consisting of three converter units connected in and out with internal LV/MV transformer each (380V/22000V).
Then there is a step up transformer from 22kV to 66kV inside the facility and a 66 kV OHL up to the substation where the POC is located. The OHL is almost 2km long
How can I take into account the losses of the different sections MV and HV?
Regards
Pierluigi
  • 3 weeks later...
Outside of PVsyst in excel
so this means that PVsyst only is able to give a result as if the POC is before the step-up transformer.
To have a realistic production forecast, I should thus calculate the loss in % due to the step up transformer and the OHL and then apply to the PVsyst result.
Do you find it correct?
Regards
Pierluigi
