kjs55 Posted June 11, 2019 Posted June 11, 2019 (edited) PVsyst v6.8.1: Nothing is copied to the clipboard when you select "Export\Copy values to clipboard". To see this, go to: Tools\Measured data analysis\Detailed results\Predef. graphs\Measured values = f(simul.)\Graph\Export\Copy values to clipboard Edited December 16, 2019 by kjs55
André Mermoud Posted August 19, 2019 Posted August 19, 2019 It is noted in the Help that the copy of Graph's values to the clipboard is not always reliable. It depends on how the graph has been internally constructed. You should consider this as a facultative bonus, and be happy when it is available...
