I designed solar rooftop in several orientations in Sketch up 2019 then imported to PVsyst .
PVsyst generates negative tilt angle on PV panels for this reason I can't go on next steps ,what should I do??
Please help ,Thank you in advance.
https://scontent.fbkk5-4.fna.fbcdn.net/v/t1.0-9/59655164_2229937417322102_5587581787275526144_o.jpg?_nc_cat=103&_nc_ht=scontent.fbkk5-4.fna&oh=3fc73054b8860d719c5207e9f0a74b4e&oe=5D6721CA
https://scontent.fbkk5-5.fna.fbcdn.net/v/t1.0-9/58745233_2229939940655183_369212740432035840_n.jpg?_nc_cat=100&_nc_ht=scontent.fbkk5-5.fna&oh=01485f793d55bea2d7af058c563e068b&oe=5D2E91FC
https://scontent.fbkk5-1.fna.fbcdn.net/v/t1.0-9/59400424_2229941647321679_903479141314068480_n.jpg?_nc_cat=109&_nc_ht=scontent.fbkk5-1.fna&oh=49338fd9273cdce6271b132890a8ddc1&oe=5D60F5F1
Yes that is problem in PVsyst. You might need to manually place them, by first setting the azimuth to face that direction, and then set the tilt.
  • 2 months later...
PVsyst doesn't manage negative plane tilts.
A tilt of -25° towards an azimuth of -90° corresponds indeed to a tilt of +25° towards +90°.
This erroneous generation takes place in the Sketchup import file. We will manage for correcting such a situation in a next version of PVsyst.
