ESL_2010 Posted March 28, 2019 Posted March 28, 2019 Hi folks,I'm modelling a simple grid-connected PV system and have added a battery under the "weak grid" scenario.In this location however, it is not permitted to export any power back to the grid. When I try to set a limit using Energy Management > Grid Power Limitation, it does not allow me to set the grid power limitation to anything less than 1kW.The manual does not suggest that there is a requirement for grid export to be >0. Can anyone confirm if this is indeed the case, whether I'm just doing something wrong, or is this a bug?
André Mermoud Posted April 17, 2019 Posted April 17, 2019 Perhaps you are using an old version.In the Weak grid definitions you have this option:Group "Operating conditions", checkBox "Allows solar injection into the grid."
ESL_2010 Posted April 17, 2019 Author Posted April 17, 2019 Perhaps you are using an old version.In the Weak grid definitions you have this option:Group "Operating conditions", checkBox "Allows solar injection into the grid." Thanks André - I had indeed failed to spot that checkbox even though it was obvious once you pointed it out.
