While designing a PV connected grid... I pressed on systems to select the PV module and the inverter, however, I am unable to choose the inverter type.
Not sure what is the problem but there is no options shown in the inverter list
  • 2 years later...
Is your problem visible on the entire inverter database or only on an inverter that you have imported/created?
If a component is not visible in the drop-down list from the system, this indicates that the component is not fully defined in the database and that it cannot be used for a simulation
