AKE Posted February 5, 2019 Posted February 5, 2019 In 6.78 I encountered a bug in the PVsyst Report when simulating a system with mixed orientationes (e.g east/west). After a little testing, the bug seems to appear only when there are multiple inverters.The losses for- PV loss due to temperature- Module quality loss- LID- Mismatch- Ohmic wiring (DC)are all divided by 2 in the loss diagram, so e.g. Ohmic wiring -0,2%, instead of -0,4%.Another example: LID loss on page 1 (PV array loss factors): -1.0%But LID loss in the loss diagram: -0.5%The resulting energy in MWh however seems to be still correct, so I assume only the displayed numbers for these losses are bugged.
André Mermoud Posted February 5, 2019 Posted February 5, 2019 You are right. The "Array nominal energy" is indeed a new intermediate calculation (introduced in V 6.77) , which was not correctly calculated for Mixed Orientation in the versions 6.77 and 6.78. This will be corrected in the version 6.79, to be released within about 2 weeks.This only affects the losses expressed as a percentage in the loss diagram (up to EArray at MPP). The simulation results are quite correct.NB: In the meantime If you need a correct report, the can download the version 6.76 from our web site www.pvsyst.com, and install it in parallel with your exiting version. Both versions may by used without interaction.
