Eva.D.McCoy Posted October 1, 2018 Share Posted October 1, 2018 Hello,I recently was in need of exporting one year worth of hourly humidity data (from meteonorm 7.2) and couldn't find a way to do it directly. I know how to export these kind of data for other parameters (for example GHI, could save a hourly file during simulation) but couldn't find the humidity parameter to add to the result export file. I ended up exporting each month separately from the meteo data graphs tool (that doesn't allow for one year hourly graph/export). Is there a way to do it?Thanks in advance and best regards Link to comment Share on other sites More sharing options...
André Mermoud Posted October 17, 2018 Share Posted October 17, 2018 You cannot export Meteonorm data. Meteonorm is also a software, sold as such. By contract with the Meteonorm team, the use of the Meteonorm data implemented in PVsyst is reserved to the internal use within PVsyst. If you need data for other uses you should buy the Meteonorm software. Link to comment Share on other sites More sharing options...
