you have defined 2 different orientations in the shadings part
Hi guys,
I created a PV-field in a shading scene using table raws and single tables. Both have same orientation and tilt (25°/23°).
PV_Syst is giving me the error message "you have defined 2 different orientations in the shadings part". It´s requesting to use "multi-orientation" to fix this, but that action creates another error message. "Orientation #2: No shading field defined"
:roll:
Any advices?
This is very strange indeed.
With which version of PVsyst ?
Please check that you have defined a reasonable value in the Project's settings parameter: in the project's dialog, button "Project settings", page "Other limitations", item "Discriminating orientation difference between shading planes". The default value is 1°.
If this is OK, please send your whole project (using "Files > Export project" in the main menu), to support@pvsyst.com.
  • 3 months later...
