Helios210 Posted August 6, 2018 Posted August 6, 2018 What do the quantities PlAzim and PlTilt refer to?I often get erratic values in my hourly output file such as:PlAzim-900.001490PlTilt40.36552.6926036.5099.28450.0009What are these numbers indicating?Thanks,H.
André Mermoud Posted August 28, 2018 Posted August 28, 2018 These values are simply the plane tilt and plane azimuth of your tracker, at a given time. I don's see in which way they are erratic: these are calculated from the tracker's position (phi angle, axis tilt and azimuth, depending on the tracking mode) and are quite real angles.
Helios210 Posted August 30, 2018 Author Posted August 30, 2018 Hi André,Thanks for the reply - I meant no disrespect!My comment about the erratic nature was more referring to the PlAzim values. This output was achieved using a single axis tracker so I didn't understand why the azimith changed.Thinking on it though I realize that one could interpret it as a change, and the very small 0.00014 value is when the tracker is at, or very close to the stow position - this clears up my miss-understanding so thank you.Best,H.
