klerindias Posted January 12, 2013 Posted January 12, 2013 Hello,How to get results with modules set vertically or horizontally.Results should differ (position strings of cells with bypass diodes) with PV plane in sheds in this 2 cases with any pitch,but dont know how to set it.Regards
Rapha123 Posted January 14, 2013 Posted January 14, 2013 You can specify this using the electrical effect of the mutual shadings in the orientation tab, putting in the dimensions of the strings. Also when you partition modules in the 3D shading diagram you can specify the orientation of the modules.
klerindias Posted January 14, 2013 Author Posted January 14, 2013 Hello,I dont know how to do it, couldnt find it.But i want to see difference in yield when i put on construction modules vertically or horizontally with same numbers of modules.Red/Green/Blue colors shows how bypass diodes are set.How to do it in PVsyst, when i want put strings of modules vertically and horizontally and then add influence strings in this 2 cases.Like in image below:What will be yield in case 1 and case2? When i trying to do it i got same results, because i dont know how to set strings of cellshttp://img845.imageshack.us/img845/8291/shadowingverticallyandh.jpgHere is how i did it in PVsysthttp://img801.imageshack.us/img801/8291/shadowingverticallyandh.jpgAnd how i set Field Partition in module chains, i dont see here possibility of setting substrings of cells...Horizontally (L:3x1.65m W:0.99):http://img255.imageshack.us/img255/1845/horiz.jpgVertically (L3x0.99m W:1.65):http://img138.imageshack.us/img138/2106/verticald.jpgand this results cant be different..., where put here bypass diodes influence?
