V6.73 AC losses
unilhexio
In the latest update, AC circuit Vac is directly related with Iron loss:
https://image.ibb.co/cpL9ay/Screen_Shot_05_30_18_at_08_26_AM.jpg
This is, I can not set the injection voltage to 230 kV, for example, because I obtain too high Iron losses and an error message. (2 Vac in injection point is 200% in Iron losses; in the same way 20 Vac is 2000% in Iron losses!!)
Yes there is indeed an accidental error in this version 6.73. This will be repaired in the next version.
In the meawhile, you should define these values with the version 6.72 (you can always download an old version, and use it in parallel of your usual working installation).
In this is already defined and you don't open this dialog (page "wiring losses"), the parameters will stay correct for the simulation.
  • 2 weeks later...
  • 2 weeks later...
  • 2 months later...
  • 2 weeks later...
