Hello Dear all,
I'm developing a far shading analysis and I am trying to use the option to import the horizon file from Meteonorm or PVGis as specified in the help section of PVsyst.
But when I download the file from Meteonorm it is in .rdm and when I download the file from PVGiS it's on txt. As it is a lot of data I want to know how can I convert the file into a .hor
so that PVsyst can read it.
Also, when I click on the "Import" option, I do not see PvGiS within the options, if a choose these data how can the PVsyst read it?
Thank you for your assistance
Best Regards
  • 3 years later...
The horizon profile may be defined manually by a set of (Azimuth/Height) points in degrees. These may be from on-site measurements (using land-surveyors instruments like compass and inclinometer).
They can be imported from several sources:
From your workspace:
· PVsyst internal file - all horizon files that are saved in your workspace
From external files:
From web sources directly (requires an active internet connection)
Please read :http:// https://www.pvsyst.com/help/horizon_import.htm?zoom_highlightsub=Import+horizon
