Is there a way to use "Save to PDF" function without locking the PDF? It would very helpful if I can disable this so I can compile the pdf reports in one file.
Else, can you provide the password to unlock the pdf?
Thank you.
  • 2 weeks later...
  • 3 weeks later...
  • 1 year later...
We'll allow document assembly in the generated PDF file, starting from PVsyst version 6.74.
So you will be able to include the PVsyst report inside other PDF documents !
Has this been implemented? We have Version 6.77 installed but are not able to combine PDF files. This is an important issue because some proposals need to be submitted as a single PDF.
  • 1 month later...
  • 2 years later...
On 6/5/2018 at 9:15 PM, Sylvain Pepoli said:
version 7.2.16 document assembly is not allowed! This is quite a problem for including it in the other documents.
If I'm not mistaken, I think there's another version running right now
instead of this version 7.2.16, Which you are talking about. So I recommend you to check for the update and then check it hope it solve your issue.
