Shading simulation using Dual cells module(144 cells)
Luciano Nadai
Hi everybody,
I was working in a project with many objects(air conditioning, trees..) that can cause shadow/losses, so I did two differents simulations, first one using 72 cells modules and second one using 144 cells(for example Canadian solar CS3U-330P).
And I have not seen any differences between these two scenarios. In shading animation tool, using 144 cells, even the shadow affect just a little piece of module, the whole module is affected and is shown as "yellow color". I was expected that just half module could be affected, once these modules are 72 cells in parallel ! I really I did not understand the results !!!!
  • 1 month later...
