Simulation approach with many orientations on the roof configuration
I am studying the application of BIPV systems on the roof configuration in the equator region. How to approach the PVsyst program to calculate the performance of the BIPV system on the configuration of the roof area with a great variety of orientation and slope angle as in urban settlements. The case example is attached. The calculated is not a block of settlements (figure-1) but some groups of roof configurations, about 7-10 roofs (figure-2). Thanks.
  • 1 month later...
In PVsyst you can define up to 8 different orientations.
Some of your roofs with a same (or very simular) orientation may perhaps be grouped.
Otherwise you should define several different variants, and add the results at the end.
