The basic information is indeed the cables resistance, as seen from the input of the inverters. You should calculat this using your usual electrician rules.
The STC percentage is only a simplified way of defining a "reasonable" value for a new project. You don't need to calculate it (it will be calculated automatically when you will enter the cable resistance).
  • 2 weeks later...
