marianzinho Posted November 27, 2017 Posted November 27, 2017 Hello, my name is Mariano and im an industrial engineer from Argentina. Im new using the PVsyst software, so one colleage send me the results of a simulation as a base to learn. I've tried several times to simulate the same project but unfortunately im not getting the same results as the one my friend sent me.I think my main problem is with the 3D Near Shading modeling. I would like to ask if someone could help me with the inputs and the 3D modeling to get the same results.link with simulations: https://www.mediafire.com/file/zhw1mtaze3w219t/SIMULACIONS.rarThank you very much!Mariano
praveenksadh Posted April 11, 2018 Posted April 11, 2018 Hi,First of all both the reports having different weather parameters and in your simulation losses after inverter not considered however correct the same.As both reports generated with different Versions hence there may be l little difference but not so more.
