Hi.
I ran into the same problem. one solution is to choose from "Shading Screen Construction" "view"menu- "save this view for the report". Then it shows the present view in report as well.
Hi.
Thanks a lot. It works!
Hi there,
I just want to clarify if the setting of "Rs from Low-light efficiencies" under the definition of a PV module are depending from the module pan file OR it depends with the PVsyst version?
I've tried to replaced a certain project of different kind of module and some modules showing this setting but other types are not. Appreciate your kind review and explanation regarding this as this is giving a significant impact on the generation output of the project.
Snapshot can be view from the link below.
https://www.dropbox.com/s/50f2djyqv8tefq0/Rs%20Low-light%20efficiency.PNG?dl=0
Thanks,
Bris
