J. Behrschmidt Posted October 18, 2017 Posted October 18, 2017 Hello, I face problems with the results for inverter loss over nominal inv. power, which seems to be to high. I see the cause in the system defintion, see picture attached. I have a 36KW inverter with four inputs, but the Global inverter power is shown with 65 instead of expected 72. When I reduce to four inputs the Global inverter power is shown with 32.5. The Inverter loss over nominal inverter power is calcluated with 1%, which seems to be to high in my opinion. When I do not use the multi-MPPT feature, the global inverter power shows the correct value with 72kW, but as result for the inverter loss over nominal inv. power I get 11%. I did the calculation with V6.63 and V6.64 its always the same.
André Mermoud Posted October 19, 2017 Posted October 19, 2017 I have tried your configuration and everything is OK (Global Inverter's power = 72 kW, and PNom ratio = 1.22).Now I observe on your picture that your inverter is not from the PVsyst database (grey background). Please check its parameters (namely the PNom AC value).
J. Behrschmidt Posted October 19, 2017 Author Posted October 19, 2017 Hello André,in my opinion the values are correct. I attached the .ond. Maybe you see what's wrong.Huawei_Sun2000_36k-8p2-haller.zip
