In version 6.64, how is the cell temperature calculated and what are the variables used in the calculation? Also, what is the cell temperature variable name in the output file window used to generate the output file?
I am using a TMY3 file to create the .MET and .SIT files.
Thank you in advance.
The cell temperature is equivalent to the array temperature, the variable is named "TArray".
During the simulation the TArray is evaluated at each hour using the Energy balance described in the help " Project design > Array and system losses > Array Thermal losses"
