I ve tried to import Meteo data from Explorador Solar now that it is available but it makes it badly bcs of a question of time shift in clear days (355 minutes!)
Could you guys check it?
BR Jose
Hello Jean-Marie,
I cannot attach it as it weighs 900 kB but the problem could be solved. As you said Latitud was wrong, it came in "." and in Chile we use "," so the latitud was 702.756. I just removed the last "6" and it turned to 70.275, so manually you do that trick and it goes perfect afterwords.
Thnx BR
