Can't able to keep 20 and above Modules in series in PVsyst 6.6.3.
But it was supported in the older versions.
Suggest to solve this.
There may be possibility that in older version "Lower temperature for Absolute Voltage Limit" set @ 0°C however as per attachment "PV Syst" Set temp. is -10°C resulting 1020V which is exceeding inverter maximum input voltage and not allow to take 20modules in series due to same.
Hence go to Project → Project Setting → Design Conditions and set the "Lower temperature for Absolute Voltage Limit" value as weather file.
Also find below details.
