It's Beatriz, I am simulating with the version V6.62 the Bifacial system and I have a few question relate to the albedo.
1) What's it the different between the albedo in the Bifacial system and the albedo in project settings?
2) if they are the same, I understand that we should use the same albedo in both cases. Shouldn't it?
Thank you so much in advance,
This is quite different:
- the albedo mentioned in the project concerns the full "far" area in front of your installation. It is used in the transposition model.
- The albedo of the Bifacial model describes the reflexion of the ground just under your PVsystem (roof, grass, rocks, painting, etc)
