Lockyy Posted April 24, 2017 Posted April 24, 2017 Hello, I have problems with the Import. I tried with a small plant and there have been no problems but with a larger plant, there are a lot...What I did:1) Imported a DAE-3D-file from AutoCAD -> the tables are "objects"2) Transformed to PV faces3) Deleted the objects -> just PV-fieldsWhat happens: A lot of warnings like "the object "PV-field #46" is penetrating the PV-field "PV-field#45"." In fact, the distance between the tables is 10 cm (so >2-3 cm)If i delete this table, it happens somewhere else.Any hints?
Sylvain Pepoli Posted April 25, 2017 Posted April 25, 2017 Hello,You can disable the interpenetration check by clicking on "Tools -> Disable fields interpenetration check".
Lockyy Posted April 25, 2017 Author Posted April 25, 2017 And just ignore everything? Why is this happening?
Sylvain Pepoli Posted April 25, 2017 Posted April 25, 2017 You're right I didn't read that the space is 10 cm, sorry.Can you please send me the scene to support@pvsyst.com ? I'll have a look why this happens.
IslamYaseen Posted July 24, 2018 Posted July 24, 2018 the pv field table field is confused with the object parallelpiped pv systwhy this happen?
wangpv Posted August 17, 2023 Posted August 17, 2023 On 4/25/2017 at 10:19 PM, Sylvain Pepoli said: You're right I didn't read that the space is 10 cm, sorry. Can you please send me the scene to support@pvsyst.com ? I'll have a look why this happens. Could you tell me why and how to avoid that? Thanks!
Stéphane Posted August 17, 2023 Posted August 17, 2023 1 hour ago, wangpv said: Could you tell me why and how to avoid that? Thanks! Dear wangpv, If you are encountering the same issue, please send us your project to support@pvsyst.com and we will investigate and let you know what is the cause. Thanks
