Access violation at address in module error
Hi All
There are several of us working on PVsyst in our office and so we moved the central PVsyst Data directory to a common network location. This seemed to work, but having reinstalled PVsyst on a few machines I am getting the following error when I open the 'System' tab.
Violation d'acces a l'adresse 005DD10E dans le module 'PVSYST5.exe'. Lecture de l'adresse 00000068
Translated as: Access violation at address in module 005DD10E 'PVSYST5.exe'. Reading address 00000068
I also can't open the inverter / Module database as the programme hangs.
Has anyone come across this and found a fix?
Hi Yann
Yes, version 5.60.
The problem only occurs when I use a network drive (I've tried several) and it doesn't matter which computer accesses it. I've tried a few options with Andre, but not luck!
