davidv86 Posted February 8, 2017 Posted February 8, 2017 Hello,I use PVsyst everyday on my job. I use to do simulations of PV Farms about 2 MWI consider Ground Mount PV Arrays as a Sheds, but is difficult to draw irregular pv fieldsI have seen a report from other company that is able to draw irregular arrayshttp://thumbs.subefotos.com/d827b07a1edec2c73a721bf3b354367fo.jpgI want to know the way to do it.ThanksDavid
Sylvain Pepoli Posted February 9, 2017 Posted February 9, 2017 Hello davidv86,I would suggest that you use the "Zones of tables" tool in the shading scene.Please refer to the PVsyst help section called "Project design > Shadings > Near Shadings: 3D construction > Construction tools > Zones of tables".This way you will be able to fill any area with PV tables, and if you imported ground data the generated tables will land on it automatically.
davidv86 Posted February 9, 2017 Author Posted February 9, 2017 Sylvain,Thank you very much for your response.Actually I have only one doubtWhen you define a Zone of table, does not appear the shed to shed slope, that is important for considering the N-S slope of the terrain.Could yo give me some feedback aboud this,?Thanks in advanceDavid
Sylvain Pepoli Posted February 9, 2017 Posted February 9, 2017 The shed to shed slope should be automatically set by the zone when it is filled, and tables will have an automatic baseline slope too.When using zones, we should not talk about sheds actually because it is generating single independent tables.
