hy0709 Posted January 24, 2017 Posted January 24, 2017 When I set up the overpower parameter of inverter, I found that the minmum difference between Nom ac Power temp and Max ac Power temp is 10℃.If I set Nom ac Power temp up to 58C, then the maximum of Max ac Power temp is 48, but I need to set it up to 50C.Can you help me?Thanks!
André Mermoud Posted January 28, 2017 Posted January 28, 2017 This limitation is for the parameter's definition safety. We think that a higher slope of the PNom variation as function of the inverter temperature doesn't make much sense.
