Hello all,
I am designing a system using an inverter which has a DC/AC ratio 1.3. When I load the inverter with %130 DC and total overload loss of %3.5, system gives an error "The inverter power is strongly undersized" although it could have such input. Later on, I have changed from hidden parameters section, "Detailed Simulation Verification Conditions" tab, "Limit Overload loss for design" from %3 to %5 and nothing changed. I also adjusted "PV Array Power is stongly oversized" ratio from 1.6 to 3.
Shortly, despite all faults, I need to continue designing and simulation. Is that possible with any other parameter adjustment?
Thanks in advance.
  • 4 weeks later...
The definition of the parameter "Limit overload Loss" has been moved to the Project's parameters (button "Albedo&Settings") since a long time.
The value in thew Hidden parameters only acts as initial value for new projects.
