Batch Simulation > Warning: The shading table has not been computed
I'm trying to run batch simulations for N-S single axis trackers with a tilt of zero. All I want to do is vary the pitch. In the Parameter Specification, 3D shadings parameter I select Pitch E-W between trackers and backtracking activated. I did notice that the parameter word "Backtraked" had been misspelled in the output file.
I get the message: Warning: The shading table has not been computed in the results
I ran this in batch mode with just one data point for the pitch:
PVsyst simulations Batch mode;;
Simulation parameters and results;
File Created on 01/11/16 10:24;;
Project ;;;Sample PVsyst;;
Variants based on;;VC2;ATI_Duratrack_HZ 2.1 MW DC;;
Ident;Trackers;Backtraking;Simul;Error;E_Grid;
;Pitch EW;;Comment;;MWh;
;[m];Y/N;;;;
SIM_1; 4.00;Y;ATI_Duratrack_HZ 2.1 MW DC ;Warning: The shading table has not been computed;4082;
Thanks for your time,
Mike Reed
  • 3 weeks later...
This error message "The shading table has not been computed" appears here by mistake.
In fact the shading table is correctly computed at the beginning of the simulation, which arises after this check. This should be corrected in the next versions.
  • 1 year later...
I had the same error "Warning: The shading table has not been computed" in Version 6.68 too.
Though it says, the shading table has not been computed, it actually did.
You can verify this by checking the option "produce a pdf report" and verify the loss calculation on the detailed loss section, where it actually accounts for shading.
  • 2 years later...
  • 7 months later...
  • 4 months later...
