lonav Posted October 13, 2016 Posted October 13, 2016 Hi,I am trying to find a way to customized OND files. Whenever I create one from a datasheet, I see that in "Output parameters" the derating values dissappear from one simulation to another. Also when simulating w/o self consumptions included in the file. This does not happen when the manufacturer provides the OND file. Now that component files are editable (with Notepad++ for example), I have created the file from a manufacturer's .ond text file. So far it seems it works but, could you confirm this is a safe way to avoid changes in the file configuration, please?Thank you in advance,Lola.
