LoicA Posted August 31, 2016 Posted August 31, 2016 Hi,I am wondering how the albedo value is used by the process of POA irradiation calculation.Let's say we have 1000W/m² GHI. The albedo value is 0.2. Then, is the transposition process use 1000W/m² x (1+0.2) to determine the POA irradiation ?Thank you for your answer.Best regards,Loic
André Mermoud Posted August 31, 2016 Posted August 31, 2016 The albedo is computed by the transposition model, in the same way for each model. Please see the description of the Hay model in the Help "Physical models used > Irradiation models > The Hay transposition model"The Albedo component is the irradiance reflected by the ground "seen" by the plane : AlbInc = ρ * GlobHor * (1 - cos i) / 2where i = tilt angle. With horizontal plane (i=0), the albedo contribution is null of course.For a"normally" tilted plane, for ex. cos(25°) = 0.906, the contribution is 0.046; for a vertical plane, it is 0.5.
LoicA Posted September 14, 2016 Author Posted September 14, 2016 Dear Mr Mermoud thank you for the answer,Ok it's more clear now.If I am right, GlobHor = BeamHor + DiffHorSoAlbinc = rho * (BeamHor + DiffHor) * (1 - cos i) /2 ?Regarding your explanation in "Physical models used > Irradiation models > The Hay transposition model", the calculation of the POA irradiation does not seem that much difficult.POA irrad = BeamInc + DiffInc + AlbInc = we have all the constants and variables neededI will read more stuff or try to work on the hourly PVsyst result to be more confident on this topic.Thanks, Loic
