papan5069 Posted August 28, 2016 Posted August 28, 2016 Dear Team,I'm sorry if this is a repeat question but while analysing a tracker field near shading, I'm given the error "Shading Area is Less than PV Module area". I have read in the forum that this is due to mismatch in active area in 3D study, but I haven't mentioned anywhere the area required. PVsyst is taking it on its own. I have restricted my capacity of KWp during system design parameters.Can I get a help how to resolve the issue. I want to study the near shading loss using 2 tables only not with the full numbers of trackers.Expecting kind help
André Mermoud Posted August 31, 2016 Posted August 31, 2016 PVsyst doesn't take it on its own. When in the "System" part, you define N PV modules of X area, the total area is N x X. It is not a mystery. Now you have to foresee sufficient area in your 3D shadings scene for positioning all these modules. This seems rather logical.What may be sometimes confusing, is that PVsyst also checks the coherency for each orientation: this check is done for each orientation independently.
papan5069 Posted September 1, 2016 Author Posted September 1, 2016 Thanks Andre. I will get back with the results..
MGLopez Posted May 5, 2021 Posted May 5, 2021 Hello, PVsyst doesn't take it on its own. When in the "System" part, you define N PV modules of X area, the total area is N x X. It is not a mystery. Now you have to foresee sufficient area in your 3D shadings scene for positioning all these modules. This seems rather logical.What may be sometimes confusing, is that PVsyst also checks the coherency for each orientation: this check is done for each orientation independently. I don't understand the quoted answer as applied to my example : I let PVsyst select the table size by telling it the numbers of modules per row and column. In the present case, 4x16 modules, each of them being 1.14m wide and 1.646m tall, i.e 1.92 m2. So the needed area for theses 64 modules is about 122m2. PVsyst tells : "Table area : 123.1m2 / Required area : 189.5m2". How could it be so ! I agree to the first figure but totally disagree with the second one.As far as I understood, the PV tables are independant from the building shape. However, I checked that there is enough space around the table, in the table plane, between the edges of the table and the edges of the roof. By the way, this table design was defined by one well known fixing devices manufacturer (K2 SYSTEMS).Thanks in advance for your help !
