Created projects using the Hays transposition, saved and closed. Reopened then changed to the Perez within the project (not preferences) and re-ran the model. Report showing "Hays" model.
When i create a new model, no problem. I have a bunch of existing models which i need to change from Hays to Perez without having to recreate all of them again.
thanks, Mario
Today i found if the near shading is turned off, then switching between Hays and Perez works as it should (and displays on the report correctly). This points to a software glitch, as we should be able to run Perez model with near shading.
my guess is the report has a glitch. Running the models with the near shading and just changing between Hays and Perez shows the model is working correctly because production is different (minutely higher) with Perez, just not showing the correct Transposition on the report.
This was indeed a bug just in the Version 6.44, when using tracking systems: the simulation reverted to the Hay model even when specifying the Perez model.
The simulation was consistent with the report mention.
This has been corrected in the next versions.
