I'm using PVsyst V6.44.
I've selected the Perez transposition model within my project's parameters.
However, in the report, it states the Hays transposition model has been used.
I believe my project is using the Perez model for the simulation, and it is simply reporting the wrong model. I tested this theory by changing the transposition model to Hays which resulted in a 1.6% production decrease from my original simulation using Perez.
Kyle
  • 2 weeks later...
This was indeed a bug just in the Version 6.44, when using tracking systems: the simulation reverted to the Hay model even when specifying the Perez model.
The simulation was consistent with the report mention.
This has been corrected in the next versions
  • 2 months later...
I just updated to Version 6.49 and I am now experiencing this same bug. I use the Perez transposition, but sometimes the reports show Hay.
When I run a simulation and print the report immediately, the Perez transposition is correctly listed. However, when I save the Variant, open the Miscellaneous tools to change the Resulting estimation from 95 to 99, the report then shows the incorrect Hay transposition.
Cheers!
Sam
