Search the Community
Showing results for tags 'module details'.
Hello, I would like to kindly ask you how it could be possible to verify the real value (I suppose the showed value is an approximation) behind a mu_gamma showed as null on pvyst 7.2 ? See the example below for the Sunmodule moduie: Thanks in advance, Francesco
- 1 reply
- module details
- diode quality factor
(and 1 more)
Tagged with:
Hi, After updating PVSyst today i have found the following bugs: in Shading scene, zone editing, while adjusting any of the Azimuth, Pitch, Tables Spacing or Distance from ground will set the same input value to the other ones listed here in System, while selecting the modules,thr Manufacturer <year> column, the years go up to 2034 for example. I was trying to select Trina Solar 665 W module. PLease have a look. This last one has no impct, but the first one really affects the functionality and should be addressed immediately
