Search the Community
Showing results for tags 'ground data'.
Hello, We are trying to model single axis trackers on different slopes: - from +5 to -5 degrees N-S - from +5 to -5 degrees E-W The 'axis tilt' value for trackers can be changed to model N-S slopes in an array of trackers in the 3D scene. However, when we do a message appears saying "tracker axis must be horizonal for PVsyst to model the bifacial gain". Is there no way around this currently? Secondly, there doesn't seem to be a method of inputting a E-W (tracker to tracker) slope for the array of trackers. Please could you point me in the right direction if there is a way of doing this? Kind regards, James.
I am having trouble with measurements on PVsyst when I imported ground data as CSV file. All of the lengths of my field are longer than actual size. Also I have bigger area according to PVsyst's measurement tool. I created the csv file as it says in the pvsyst help file. In addition, all of the lengths are measured in the field by Topographical Engineer so I have approved results in terms of calculations and other stuff. Thank you.
