Nuno.11
  1. Good afternoon PVsyst team, My name is Nuno and I work at Universal Kraft as a PV Design Engineer. I am posting this message to report a bug that our technical team came across with this new version of PVsyst (8.0.12). When simulating the hourly (energy) production profile, the PVsyst report (.pdf) shows the energy produced in kW/year which must be kWh/year and, besides this, the value presented has 3 order magnitude difference. This means that the value presented in the PVsyst report (kW/year) should be MWh/year. Could you please verify/confirm if this happening with other costumers or if this is a problem that only our team is facing. Thank you so much for your support. PS: I tried to upload the reports but the forum is returning an error (Error code: -200)
  2. Good afternoon Agnes, Our team completely understands your position and the aim for neutrality in this topic. Thank you for your reply and availability. Best regards, Nuno Graça
  3. Good afternoon PVsyst team, I am reaching out to you in order to check if your team could clear a doubt our technical team has. Regarding the meteorological databases our team already checked that PVsyst team did a study comparing some of them. However, some databases such as Solargis, Solaranywhere and Solcast are not included in this study. Hence, our team has some questions: Does your team have any recommendation on this ones? Comparing these three, what are the differences, in the results values (GHI and Specific Production) between them? Does your team have a preferred database that you consider as most accurate? Anyway, we highly appreciate your opinion/recommendation on these 3 databases (Solargis, Solaranywhere and Solcast). Thank you for your attention and availability. Best regards, Nuno Graça
  4. Good morning André, Thank you for your reply and confirmation. All the information that you gave us it will be very helpful. Once more, thank you for your attention and patience.
  5. Good afternoon André, Thank you for the reply. Just one question. Regarding what you wrote, our team should consider the minimum temperature during the sunny hours which is -28.5 ºC, correct? Once more, thank you for your attention and patience André
  6. Good afternoon PVsyst team, My name is Nuno and I work in a Renewable Energy company as a PV Design Engineer and our team has some doubts that we would like to clarify, but we feel that we need your input, since your team is the one that developed the software and knows everything in detail. The main doubt that our team struggling with is regarding the Design's Temperature Parameters. I am attaching to this post 2 PDF files which contains the weather data measured by a weather station near the project location (9 km far away, approximately). The Temperature_Full_Days.pdf file shows the temperature measured during the 24 hours of each day considered and the Temperature_Sunny_Hours.pdf file shows the temperature measured during the sunny hours of each day considered. As you can see in the Temperature_Sunny_Hours.pdf file, in 1800 hours of sun (from 8 a.m. until 5 p.m. - during the months of December 2021, January 2022, February 2022, December 2022, January 2023 and February 2023), we got 105 hours where the hourly average temperature was lower than -20 ºC and 20 hours where the hourly average temperature was lower than -25 ºC. Our question is: Shall we consider the Lower Temperature for Absolute Voltage Limit as -25 ºC? Shall we consider it as the minimum temperature of the sunny hours of these months (-28.5 ºC)? Or shall we consider it as the minimum temperature of all hours of these months (-29.4 ºC)? Also, could you please tell us what would be the implications and consequences if we have considered a higher temperature than the one we should consider? If you need more information, like the PVsyst Project file and all the weather data that we have, just let me know. Looking forward for your answer and thank you for your attention and availability.
