Lazare Fesnien
Administrators
  1. Hi, The optimizer's properties and operating conditions are very specific to each manufacturer. We need a close collaboration with the manufacturer for implementing them in PVsyst. An update of the database is in progress for the next version
  2. Hi, We update the database using the requests of the manufacturers, and publish it with each new issue of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos, page Component database
  3. Hi, We update the database using the requests of the manufacturers, and publish it with each new issue of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos, page Component database
  4. Hi, For Li-Ion batteries, this is not so simple. For defining a battery pack, you should define a single cell, and then construct the battery pack as an assembly of these cells. Constructing the cell's file requires to avail of detailed datasheets of this cell. And the elaboration of the parameters passes by a detailed analysis of these data (especially the charging / discharging curves) The best way is to start from an existing cell's file, of the same technology (chemistry). NB : The battery model is fully described in the Help " Physical models used > Batteries - General model description" And also " Component Database > Batteries > Batteries - Main interface > Batteries - Basic data (Lithium-ion)" and subsequent topics.
  5. Hi, We update the database using the requests of the manufacturers, and publish it with each new issue of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos, page Component database
  6. Hi, It is not possible to fill a zone with domes for now
  7. Hi, In the present time only Bi-facial models for unlimited sheds or unlimited trackers are available. This means that the edges of the system are not taken into account, and the contributing ground is from the first shed bottom, and the last shed + pitch. Threrefore the model is not applicable to experiments on a single (or double) array for example. You should define a system compatible with these hypothesis: - Either in the "Orientation" dialog, you should choose "Unlimited sheds" or "Horizontal axis Unlimited trackers". These involve a generic analytic calculation of the mutual shadings. In this case you should not define a 3D shadings scene, as the shading effects would be accounted twice. - Or in the 3D shading scene, you have to define "PV Tables as Sheds" or "Tracking PV planes". These objects define arrays. If you define several such objects, they should be identical (same orientation, pitch or table/trackers widths). In this case you have to define "Fixed orientation" or "Tracking horizontal axis" in the "Orientation" part. And the bi-facial model will establish a dummy "Unlimited Sheds or Trackers" corresponding to these parameters.
  8. Hi, We are sorry to hear this and apologize for the inconvenience. A lot of configuration is possible in this tab, can you give me more details about this bug ?
  9. Hi, You can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos, page Component database
  10. Hi, The optimizer's properties and operating conditions are very specific to each manufacturer. We need a close collaboration with the manufacturer for implementing them in PVsyst.
  11. Hi, Thanks for your bug report. Please read the related post from our FAQ: https://forum.pvsyst.com/viewtopic.php?f=17&t=5453 Sorry for the inconvenience and best regards.
  12. Hi, Sorry, with stand-alone systems, only one sub-array is possible. Therefore one only orientation. This is a limitation of PVsyst, that we should improve in the next months.
  13. Hi, We use to update the database using the data provided by the manufacturers. However despite several reminders, SMA has never updated the database since more than 5 years, so that we decided to include some of their inverters from the datasheets available on the web. But SMA people were not satisfied at all when seeing our definitions of their inverters. They asked for retrieving them immediately. Therefore please ask SMA for their OND files about these devices. NB: You can always define an inverter from datasheets by yourself: you have a tutorial on Youtube for that:
  14. Hello, We update the database using the requests of the manufacturers, and publish it with each new issue of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos, page Component database
  15. Hello, Sat = 23% means that the share of satellite data when interpolating is 23%, the rest corresponds to station data, interpolated from nearby stations. Meteonorm does use a mixture of satellite and station data. The further one is from the stations the greater the weight of satellite data. For more information about meteonorm, please also look at their documentation. For example their handbook's chapter 7.2 describes the interpolation in more details https://meteonorm.com/assets/downloads/mn80_theory.pdf
  16. Hello, We have designed several online video tutorials which we invite you to watch: https://www.youtube.com/channel/UCMzsEWHk3f7XD_dg1lngmzg
  17. Hello, Thank you for pointing this out. This is a bug that we will correct for version 7.2.4. This only affects the display of the results, but the yearly results are unchanged.
  18. Hello, Can you send us on the following email address your request with your project and screenshots? support@pvsyst.com
  19. Hi, Which "many components" ? In principle we never suppress any component from the database, as users may have defined them in their projects. But sorry, we had to do an exception here. SMA people were not satisfied at all when seeing our definitions of their inverters from datasheets in the PVsyst database. They asked for retrieving them immediately. Therefore please ask SMA for their OND files about these devices. NB: You can always define an inverter from datasheets by yourself: you have a tutorial on Youtube for that:
  20. Hi, Yes, there is indeed an error in the version 7.2, that we have to investigate. Please revert to the previous version 7.1.8 for your simulation. You can download it from our website www.pvsyst.com, and install it in parallel with the version 7.2.
  21. Hi, Thank you for this feedback. Good writing is : PVsyst
  22. Hi, Please send us your project on support@pvsyst.com in order to analyze your problem.
  23. Hi, Indeed, we just elucidated two bugs in version 7.2, for bifacial systems: - One in the display of the report, where the “bifacial model geometry” section is not correct, - The other is an error in the computation of the diffuse on the rear side of modules for bifacial tracking systems. This in turn largely affects the losses diagram. We will be publishing a corrective to these two errors in patch 7.2.1, as soon as possible.
  24. Dear, The message in red indicates an error. You must therefore make changes in order to match the characteristics of your inverter. For more information, you can read the links below : https://www.pvsyst.com/help/inverter_array_sizing.htm?zoom_highlightsub=oversize https://www.pvsyst.com/help/inverter_operating_limits.htm Regards,
  25. Dear omairahm, The message in red is normal because your inverter has a very high power compared to the Total STC power of your PV array. You have a 1665 Kwp PV array, so you must choose an inverter between 1200 and 1500 KWac Regards,
