sauld joined the community
phihash5 joined the community
mut joined the community
JohnC18 joined the community
huybaor joined the community
roni_hajianto joined the community
ERICMC joined the community
StarkPoint joined the community
Brooke Sargent joined the community
- 3d shadings
- near shading 3d scene
- 3d shadings
thanks for the reply, I tried it but it didn't solve the issue - Earlier
