Morget joined the community
Madj joined the community
Does PVsyst have any stow- strategy in the simulation when backtracking is on. The reason I am asking is because in "orientation" tab when backtracking is on, the modules will go to stow at sunrise and sunset (when moving the sun in the screen shot below to the extreme ends) -
My PVsyst version is 7.2.16. -
Ohmic loss is proportional to power. Abu Dhabi has much higher irradiance compared to Berlin. Also, not sure if it is intentional, but you're simulating the 10th year of operation. If unintended, be sure to set it to year 1 on the degradation tab. Ohmic losses - PVsyst documentation
mariem joined the community
NEILPD joined the community
Meklit joined the community
SONA joined the community
Hi, Indeed the custom import process can be a bit tricky. In the upcoming release of version 8.1, we will introduce a new assistant to help guide users more easily through the construction of the .MEF file. When importing sub-hourly data, please ensure that the time step is correctly set to 1 minute rather than the default 60 minutes. The warning message you received indicates that the imported irradiance values are very low compared to the site’s clear-sky model. Is the site correctly defined? If you are importing measured data, it may also be worth checking whether the solarimeter requires calibration or whether the units have been properly specified. Feel free to send us your site and CSV file at support@pvsyst.com so we can take a closer look. Kind regards,
