None of the methods proposed thus far in this thread work for me over the entire PVsyst date column. You can see the problem if you open the PVsyst output CSV file in Excel and add a new column with the formula =DAY(PVsyst_date) and drag it down. The root problem is that the PVsyst output date column contains mixed data types/formats (both serial numbers and text strings). Here is what I finally found to work for the default PVsyst output date format "DD/MM/YY; Hour; (Excel)": year =IF(ISNUMBER(PVsyst_date+0),YEAR(INT(PVsyst_date+0)),1900+VALUE(MID(TRIM(PVsyst_date),7,2))) month =IF(ISNUMBER(PVsyst_date+0),DAY(INT(PVsyst_date+0)),VALUE(MID(TRIM(PVsyst_date),4,2))) day =IF(ISNUMBER(PVsyst_date+0),MONTH(INT(PVsyst_date+0)),VALUE(LEFT(TRIM(PVsyst_date),2))) hour =IF(ISNUMBER(PVsyst_date+0),QUOTIENT(ROUND(MOD(PVsyst_date+0,1)*1440,0),60),VALUE(MID(TRIM(PVsyst_date),10,2))) minute =IF(ISNUMBER(PVsyst_date+0),MOD(ROUND(MOD(PVsyst_date+0,1)*1440,0),60),VALUE(RIGHT(TRIM(PVsyst_date),2))) second =IF(ISNUMBER(PVsyst_date+0),MOD(ROUND(MOD(PVsyst_date+0,1)*86400,0),60),0) xlsdatenum =DATE(year,month,day) + TIME(hour,minute,second) - Last week
Yes that is correct
- 7 replies
- irradiance
- rpoa
(and 5 more)
- 7 replies
- irradiance
- rpoa
(and 5 more)
- 7 replies
- irradiance
- rpoa
(and 5 more)
Alpha joined the community
Stefano Martini joined the community
Continuing the question: I am thinking about 1 - ignoring this shape difference and count it as uncertainty, or 2 - Consider the module as monofacial, and "boost" GPOA values with the mantioned formula: E_Total = E_POA + E_Rear * 𝜑 or E_rear = RPOA * (1 - "Structural shading factor") The second option makes sense? If so, which formula would be more accurate? Thanks! Rafael
- 7 replies
- irradiance
- rpoa
(and 5 more)
That's a very interesting topic! I am also carrying out a performance analysis, with RPOA measurement... Since it is not possible to use it on the .MET file (like GPOA), I am trying to fit the bifacial parameters (structure shading + transparent fraction) running multiple simulations and comparing the results (GlobBak) to the measured GPOA, to see which one fits best. Apart from the absolute values, all simulations showed the shape curve similar to GHI, while the measured curve showed a shape similar do GPOA: Is this have something to do with the assumption that the re-emitted irradiance is isotropic? This text below was taken from PVsyst help: Or am I doing something incorrect? Maybe "Globak" is not the right variable to compare with RPOA? Even so, would the shape of the curves would be that different? Best regards, Rafael
- 7 replies
- irradiance
- rpoa
(and 5 more)
I ran the same variant in PVsyst 8 and got a huge difference in near shading loss. Does it make sense? please see the highlighted cells below. the only difference between two is they were ran in two different versions: -
Kareem Shaaban Ragab joined the community
Thanks but there is no such thing in V 7.2.16 -
Thank you Auriane - just to ensure that I have this correct, it's best to apply the rear-side structural shading factor to the measured RPOA because it is most important is to account for the light that is realistically reaching the rear side of the modules? This equation for E_rear would look something like the following using the measured RPOA... E_rear = RPOA * (1 - "Structural shading factor") So, please correct me if I'm wrong, but it sounds like it's accurate to say that GlobBak is not by itself analogous to measured RPOA because it has been reduced by a structural shading factor, where an unobstructed RPOA pyranometer would not be. I understand that what's most accurate may be to calculate the incident irradiance on the rear side of the module, but in my experience many engineers desire to modify measured sensor values as little as possible. In such a case, would it be more analogous to combine GlobBak + BackShd so that in the performance analysis both E_rear terms reflect the rear side irradiance before being reduced by the shading factor?
- 7 replies
- irradiance
- rpoa
(and 5 more)
Inverter Power Strongly Undersized Error Message is not cleared
Linda Thoren replied to NavidSa's topic in Problems / Bugs
Hello, This limit that the error message is referring to is in the Project setting, not the advanced parameters. Kind regards -
Hello, I have a problem in a grid connected project by 25kW MID 25KTL3-X inverter. It's my pleasure if anybody can kindly help. I selected Trina solar 720Wp Panel for my project then I tried to connect one 18 modules string to one MPPT input and 2x16 modules str ings to the other MPPT input. Although I changed the limits of PnomRatio and Oversizing array/inverter nominal power to 1.6 or even 2 the "inverter power strongly undersized" error message is still not cleared and I can not go to simulation step.
- 7 replies
- irradiance
- rpoa
(and 5 more)
Please verify the Trackers diffuse shading definition in the Tools tab. If you are not using the All trackers option, verify that a representative set of trackers have been chosen. -
Pertaining to capacity or PR testing, the following equation is frequently referenced for total irradiance calculations: E_Total = E_POA + E_Rear * 𝜑 ...where 𝜑 is equal to the module bifaciality factor. My question concerns the E_Rear term: if a PV system has a pyranometer installed in the rear plane of array in such a way that it is unobstructed by structures such as the torque tube, and the E_Rear used for the physical PV system is the measured RPOA from this pyranometer, what do you recommend using for the E_Rear term to calculate an equivalent model-side E_Total? Would the E_Rear term be the output variable GlobBak, a combination of factors such as GlobBak + BackShd, or something else? Reference: Waters, Martin, Chris Deline, Johan Kemnitz, and Jeffrey Webber. 2019. Suggested Modifications for Bifacial Capacity Testing: Preprint. Golden, CO: National Renewable Energy Laboratory. NREL/ CP-5K00-73982. https://www.nrel.gov/docs/fy20osti/73982.pdf
- 7 replies
- irradiance
- rpoa
(and 5 more)
David Bowersox joined the community
I am adding this question under this thread as it might be a version-related issue similar to the above issue. I have two projects that are the same except for the shading layout. I see ~2% difference in the near shading loss (4.5% vs. 6.7%), which does not make sense for not such a big difference in their layout. The site is flat, and the module is First Solar so no backtracking. We have removed the trees, and the result didn't change. Could you please give us some idea of what we can check to nail down the source of the issue? We can't share the logs. Some screenshots are shared below. -
