It is currently Tue Aug 14, 2018 9:22 pm
PostPosted: Thu Jan 04, 2018 4:59 pm
Dears,
I tried to add a new site in Brazil.
Completed all the stages inputing data manually from SWERA (https://maps.nrel.gov/swera/#/?aL=eFtua ... 3274&zL=11).
After finishing inputing data on Geo Coordinates and Monthly Meteo tabs, I saved it.
Here comes the problem: My new added location is listed unerneath Brazil (Country menu). But when I select it and "open" the site, a completely different city is loaded, from Algeria, Africa ! Nor the names or data has anything with the ones I created.
Any suggestion, since interactive map is not working.
PostPosted: Fri Jan 26, 2018 11:41 pm
I can't understand that.
Please try again, using "Databases > Geographic Site > New".
And make sure that before saving your site, the data are indeed what you have specified. The site will be saved when you click "OK", and at this time you can check the filename.
